Group: DynoMotion Message: 8023 From: Toby Rule Date: 7/30/2013
Subject: Thread in DSP C program
Hello,
Is it possible for a program running in the DSP to tell what thread it is running under?  I have a program that I would like to behave differently depending on which thread it is running under.
Toby
Group: DynoMotion Message: 8025 From: Tom Kerekes Date: 7/30/2013
Subject: Re: Thread in DSP C program
Hi Toby,
Yes there is a global variable CurrentThread not declared in KMotionDef.h.  You will need to declare it.  See below:
extern int CurrentThread;       /* current thread that is/was executing  */
    printf("Current Thread is %d\n",CurrentThread);
Group: DynoMotion Message: 8036 From: Toby Rule Date: 7/31/2013
Attachments :
    Perfect!  And thanks for this all your previous responses – I don’t always reply to avoid cluttering the list.
    Toby
